820-01041 Short on PP2V5_NAND_SSD1
No-Clean
Board tries to startup but U9850 gets hot and board turns off.
This board had a full short on C9589 removed it and installed a new U9850, but that the new chip got fried too after I powered on the MacBook after that PP2V5_NAND_SSD1 is measuring 0.060 in diode mode, I removed the U9850 checked it and its now shorted-fried.
I then checked each pad for U9850 on the board and found no shorts, PP2V5_NAND_SSD1 measured 0.340 in diode mode after removing U9850, I also removed C9586/88/89/93 as they were a little rusted, and saw that the coil L9580 looks a little rusty, I do not have same coil from other board, schematics tell me that it is 1UH-20%-3.8A-0.035OHM out of those numbers what is the important one so I can find a coil that works is it 1UH-20% or 3.8A or 0.0350HM I assume the later one.
Anyway with all that I put a new U9850 (second one) and same thing, it gets hot and becomes shorted after trying to power the MacBook, PP2V5_NAND_SSD1 gets shorted, I remove U9850 and short is gone.
I have spent some time with this board now, very frustrating...
Thanks!
Did you inspect J8500 for liquid sign?
Look at its pins 1 & 43 first.
I cannot understand how can you burn two chips.
If you find burnt chip, think first WHY; before applying power to the board with replaced chip!
And we talked many times about analog mux, named U9850 in all recent boards...
No-Clean
Will try as suggested, can you please help me here: I do not have same coil from other board, schematics tell me that it is 1UH-20%-3.8A-0.035OHM out of those numbers what is the important one so I can find a coil that works is it 1UH-20% or 3.8A or 0.0350HM I assume the later one.
That code means the coil impedance is 1uH (microhenry) with 35 miliohm as internal resistance, designed for 3.8A as nominal current.
You should choose one coil with closest value possible for all these parameters.
The impedance is the most important property of a coil, but not always sufficient to work properly.
The design of a buck-converter will consider all these parameters...
No-Clean
Thanks for the great explanation on inductors, I will make note of it.
J8500 is perfect, diode on pin 1 is 0.443 and pin 43 1.234 not shorts wither on all other pins, surrounding area looks clean too.
When you get frustrated and desperate you make stupid decisions, that's how I burned 2 new chips...
