820-01521-02 Macbook Air 2018 No PPBUS_G3H and other Rails
Hello all,
Does anybody know in what order should I check power rails as far as importance. Example, I do not have PPBUS_G3H. Should I just stop there and chase that one down first on this board, or is there another rail I must chase down first then chase down PPBUS_G3H.
On older boards, if I did not have the above rail, all other rails were irrelevant until I figured that out first. But while I'm reading other questions on this board I'm confused about what powers need to be present 1st - 2nd- 3rd etc. in order to get PPBUS_G3H and etc. Just looking for some kind of flow chart procedure if possible.
I have voltage right now on my usb meter of 5.14v.
I do not have PP3V3_G3H_RTC at either CD3215 chips but do have PP3V3_UPC_XB_LDO 3.3v at both same chips.
And on a side note, are there any specific rails NOT to inject voltage on in order to test?
Thanks again.
First of all check diode mode to ground at F7000 and L6960; red probe connected to ground.
Do you get voltage at R7020?
R7020 0v
F7000 1.300
L6960 .465
So I take it from the direction this is going PPDCIN_G3H would be the first voltage to make sure is there before the others? Like the PPBUS_G3H was on older boards?
Thanks
You must get R7020 voltage first.
Looks like input MOSFETs are not controlled by CD3215 chips.
Post diode mode at R7020 too.
R7020 .563 diode mode
I now have 5v at R7020
Looks like input MOSFETs are not controlled by CD3215 chips (what did you mean by that?) Thanks
VBUS voltage must pass through Q3100, or other input MOSFET to arrive at R7020.
As you didn't get 5V at R7020 (initially), was because input MOSFETs were not correctly controlled.
Any voltage at F7000 now?
Thanks. I went ahead and replaced both CD3215 because there was a little corrosion around both. I now have 20v at usb meter but 0amps.
F7000 shows 12.63v but it cycles down to 0v and then back to 12.63v. it does this continually. I rechecked F7000 in diode mode and now I get OL reading and not the 1.300 I had before replacing the CD3215's.
I have all my rails except all of the cpu core voltages and PP3V3_G3SSW_SNS and PP3V3_TBT_X_S0 and PP1V2_S0SW.
I chased these all down to all the enables are not working. They all seem to come from U7800.
There was a slight amount of corrosion around U7800 also. I heated it up with some flux to get rid of any water/corrosion under it but still no go.
What things do I need to check as far as voltages on u7800 before condemning it bad? Or, am I heading down the wrong direction going after U7800 as the fault area?
Thanks
When you say secondary power rails, what rails are those? I checked all the rails on page 121. Is there another page that has the rails you are referring to?
As far as the U7800, do you know if there is firmware on that chip? Does your store sell those chips?
Thanks
Secondary rail is any other voltage than PPBUS_G3H, which derives from it; all big coil, for example.
But also voltages derived from a rail generated in base of PPBUS_G3H, or 3V3_G3H; like in page 67.
Should be good to take U7800 from donor board, to prevent any issue.
Not sure if has board specific firmware, or not.
You will need universal stencil, I suppose.
Just find one with correct pitch, no matters if bigger.
Any solder paste should be good.
Just be sure to get leaded, 183 degrees.
