820-01521 a1932 no power got 20v 1.47amp
macbook a1932 with water damage
20v with 1.47amp stuck from here.
PPBUS_G3H is 1.5v with diode to ground 0.468
PPDCIN_G3H 0v with diode to ground 0.565
theres no short circuit from the big coils.
what should i check next?
Did you note liquid sign on the audio board?
Check both sides.
Also look at audio flex and connectors.
Do you get R7020 voltage?
audio board is corroded too
j6100 connector and audio flex not so bad (looks still ok)
btw i test the board itself without any ribbon connected (removed motherboard from the case)
anyway after i put the board to ultrasonic machine on more time
now the usb meter is 5.19v 1.47amp stuck here.
PPBUS_G3H 2.1v
PPDCIN_G3H|PPDCIN_G3H_CHGR 5.1v
PP3V3_G3H 0v 0.400 (diode to ground)
u3100
PP1V8_UPC_XA_LDOA/D 1.8v
PP3V3_UPC_XA_LDO 3.3v
PP1V1_UPC_XA_LDO_BMC 0v 0.489
u3200
PP1V1_UPC_XB_LDO_BMC 0v 0.497
PP1V8_UPC_XB_LDOA/D 1.8v
PP3V3_UPC_XB_LDO 3.82v
PPBUS_G3H should appear with just 5V at R7020.
Post diode mode reading at F7000.
Corrosion on the audio board probably damaged T2.
PPVBAT_G3H_FUSE why im having 1.541 ohms? red prove to ground diode mode ofcourse
i replaced already u7000/q7065
r7063 is correct with 1k value
with diode mode red prove to ground pin1 is 1.541 PPVBAT_G3H_FUSE | pin2 0.616 CHGR_VBAT
r7020 voltage:
PPDCIN_G3H|CHGR 5.1v
ooops, I just realized U7000 is not on PPBUS_G3H circuit.
Do not touch U7000 yet.
Check R7060 voltage, if exist.
after i removed and clean Q7030/40 now got 20v 1.47amp stable on usb meter
r7060 PPBUS_G3H | PPVBAT_G3H_CHGR_R 12.6v stable
F7000 12.6v looping to 0.2v
F7000 is just for battery, as already said.
No reason to check there, unless battery is connected.
Try to put the machine in DFU now.
