820-01521 air retina stuck at 5V 0A
jadao
This one looks clean, I have 5V 0A.
PP1V8_SLPS2R is missing and diode mode is 0.330 seems a little bit off from 0,390 so I am not sure... resistance to ground is high on both boards arounf 500kOhms.
PPBUS_G3H is 0,42V with no short, diode mode is 0,455 same compared with other board.
PP3V3_G3H is missing but I think it's normal with PPBUS_G3H missing/low
PPDCIN is 5V and I get 5V on both sides of R7075 (U7000's VDDA and VDDP)
I think PP1V8_SLP2R is needed for U7000. Any guidance would be appreciated.
Thanks!
"I think PP1V8_SLP2R is needed for U7000"
Not really; only needed to adjust final value.
On T2 boards, PPBUS_G3H is the mother of all voltages.
ISL9240 can generate PPBUS_G3H with only 5V at R7020.
Post other U7000 voltages; AUX_DET, AUX_OK.
Also check diode mode to ground at C6960/70 and C7080.
jadao
Thanks for the info, very valuable!
I do have 5V at R7020.
AUX_DET is 1.3V witch seems ok according to the 5V going actually through the voltage divider.
AUX_OK seems to be NC "NC_CHGR_AUX_OK"
CHGR_RST_IN is 0V
At C6960/70 and C7080: I have 0,455 in diode mode.
