820-01521 MacBook Air 2018 with USB-C issues
sekidata
This 2018 Air came in with liquid damage in the area of the USB-C connector on the logic board. Pins 59 (20V) and 55 (Gnd) on the connector were visibly burnt, and a few nearby caps looked corroded (C6405, C6416, CC711, C3306).
After clean-up, USB is now stuck at 5V, drawing 0.08A. PPBUS is at 12.3V. I replaced both CD3215s, and I get all LDO voltages except for PP1V1_UPC_XA_LDO_BMC when plugging into port B. I replaced the Thunderbolt ROM (U2890) with no change.
The CC lines for port A (USBC_XA_CCx) are not what I see on a good board, while USBC_XB_CCx are correct. I checked resistances on the CC lines (in diode mode) and those are fine.
What should I check next to find out why PP1V1 and USBC_XA_CCx are not working?
1V1 BMC LDO only appears on the port where the charger is connected.
You can't get PP1V1_UPC_XA_LDO_BMC when connect the charger to U3200 port.
Did you test the board with both charger and battery connected?
Do you have S-UEM2 tester?
You may need to change J3300.
Check UPC_I2C_INT_L level.
"UPC_I2C_INT_L is always 0V"
That is sign of USB-C problems.
Did you change J3300?
You've said had burnt pins...
sekidata
On a good board, UPC_I2C_INT_L only changes from 0 to 1.8V when USB-C switches to 20V, so no surprise there.
I replaced J3300, with no change.
If UPC_I2C_INT_L goes low, no 20V switching possible.
SMC is advised about a problem in USB-C area in this case.
You may have broken trace, or still corroded components.
Compare diode mode readings on J3300 with good board.
BTW, SMC is embedded into T2 chip.
sekidata
Diode readings of J3300 on this board match a good board exactly.
I think you're right: there's still an undiscovered corroded component or trace somewhere that's messing things up. I'll keep looking.
