820-01521 MacBook Air first 5v stuck, now 20v but DFU error
MacLab
Hello, sorry mi English.
This is a 820-01521 MacBook Air that came not turning on whit 5v stuck. Connected the mac in DFU mode and apply a revive option but shows the 75 error . Now the usb meter register 20v but in DFU mode have the same issue.
In some YouTube video saw that maybe the issue was the SSD so i check the rails and only PP2V7_NAND seems low (2.5V)
PP3V3_G3H_RTC =3.3v
PPBUS_G3H = 12.56v
U8600/U8607
PP1V8_SSD = 1.8V
PP2V7_NAND = 2.5V (Seems low)
PP0V9_SSD = 0.9V
SSD0_S4E0_VPP = 2.1V
SSD0_S4E1_VPP = 2.1V
SSD0_RESET_L = 1.8V
SSD0_S4E0_PCI_AVDD_H = 1.8V
Any history available, liquid sign?
What you did to get 20V on USB meter now?
Tried DFU with charger and battery, both connected?
MacLab
Came from another workshop, but no sigs off corrosion or work on the motherboard.
The battery seems death,I will find another to test again
I didn't do anything special to get the 20v. When it arrived, I used the usb tester and it had 5v, then I removed the tester and put the mac in DFU mode and when it recognized it, I tried the revive option without success. Then I tried the tester again and it was 20v.
MacLab
When trying to restore I have a different error and it does not complete the process :(
