overshoot
I have that bloody board that has no backlight.
It has image, I can confirm that and it works fine on an external screen.
Test screen is working fine and has been tested with another board.
I'm getting the EDP_BKLT_EN at 3.3V on both side of R8442 and it goes to the backlight driver as well.
I've checked around the backlight driver and no signs of liquid. The only signs of liquid damaged were found around Q7660 but I am getting a stable 5.12V on PP5V_G3S (area has been cleaned)
I've already replaced the driver 2 times as I am not getting it to switch. On my working board, BKLT_SD goes from 12.44V to 6V (multimeter used here) and backlight comes on.
On the faulty board, it stays at 12.44V.
One thing that I've noticed is the I2C signals stay at 5.12V all the time whereas with the working board, there's a drop to 4V at some point (which indicates no communication with the screen on the faulty board)
I've checked continuity from the I2C signals testpads next to R8453 and R8452 to the screen connector and it's good.
I'm banging my head against the wall on that one.
Should be simple shouldn't it be?!
