820-01521 stuck at 5v after water damage
yobad
i have 820-01521 stuck at 5v at the charger 0.04 amps.
I am not getting PPDCIN_G3H at the source of Q3100. UPC_XA_GATE2 shows 6.5v, but UPC_XA_GATE1 is 7v.
PP3V3_G3H_RTC = 3.3 v
i replaced the CD321500z, still the same problem.
PP3V3_UPC_XA_LDO 3.3v
PP3V3_TBT_X_SX 0v
PP1V8_UPC_XA_LDOA 1.8v
PP1V8_UPC_XA_LDOD 1.8v
PP1V1_UPC_XA_LDO_BMC 1.1v
Do you get same voltages on XV lines?
Where was the water spill?
Do you get all SLPS2R and AWAKE voltages?
Which is the exact PPBUS_G3H voltage?
yobad
"Do you get the same voltages on XV lines? " where is this net ? cant find it
PPBUS_G3H 12.3V
SLPS2R 1.8V
PP1V8_AWAKE 1.8V
the water was split on the trackpad
sometime after plugging and unpluging the usb cable so many times, i get 20v 0 amps
