820-01598 No backlight
yair37
no water damage, the mac was fall...
screen o.k replace cable also.
F8400 is good. EDP_BKLT_EN is at 3.3V
D8410 measurements are good.
1) 1.116
2) .800
BKLT_SCL 5.1v
BKLT_SDA 5V.
all really look good.
yair37
i was put other board instead and it work fine and also work with external screen...only backlight! there is picture.
Please, stop to quote an entire post visible few centimeters above.
What about BKLT_SD?
Tried PRAM reset?
Resolder all around U8400 and check the traces.
BKLT_EN_R must be high.
But U8400 is controlled through I2C bus from PCH, via LCD panel.
Check all R8450-52 resistors and traces.
Post voltage and diode mode to ground at SCL/SDA lines.
Also check traces from J8500 for any BKLT signal.
Do you get any voltage at EDP_BKLT_PWM?
yair37
You should check conectivity from J8500 to other components.
But this will not allow you to discard bad connections inside of J8500; with the small flex.
May need to check continuity from the other end of small cable, to the MLB components.
yair37
I was check all the BKLT continuity and thay all fine(but I will do recheck), do I need to check all the J8500 connections?
I have other same good board so I check with it also..
