820-01598 no keyboard or trackpad
KB/TP work in USB mode, before loading macOS (boot menu)?
Keep out U6855 and bypass R6854 pads.
Let see if this tricks the T2.
TP SPI data lines don't go directly to T2.
But who knows, level shifters may got damaged and affected T2 too.
Maintain the bypass and try changing U6860.
I tried another trackpad from an A1708 because I was not sure if the trackpad I was testing with was actually good or not. With the A1708 trackpad, it works in the boot menu, but then does not work in the OS or recovery mode.
macOS accesses TP through SPI bus and you have missing the required enable signal.
Did you test maintaining R6854 bypass?
