820-01598 no keyboard/trackpad and 5V on charger
ajdoc
When battery is disconnected got 5V and 0.25A on charger on both ports.
With battery connected it turns on but on login screen trackpad/keyboard is not working.
Fan on high RPM and 5V and 0.0A on charger on one port.
Second USB C port got not reaction on USB C volt meter - it is linked with U3100.
Diode mode value and voltages around U3100 looks correct.
I think I will replace but how it can be related with no keyboard/trackpad?
Any idea?
ajdoc
Replaced that CD3217 and still got the same issue.
USBC meter shows all diode mode values are correct.
Any idea?
ajdoc
"Replaced that CD3217 and still got the same issue."
With battery connected 5V and 0A on one port and no reaction on USB C volt meter on another port.
You should fix the USB-C power problem.
Try to enter DFU using SE032 pads.
Did you test the board alone on the desk?
ajdoc
"Try to enter DFU using SE032 pads."
no luck
"Did you test the board alone on the desk?"
yes, got 5V and 0.26A on charger and every a few seconds meter turns off and turn on (cycles).
U3900 and U6903 gets warm.
Did you try to enter DFU using SE032 pads with both charger and battery connected?
You need to solder wire on the pads and cut off the wire when/if the machine appears in AC2.
Check if required SLPS2R and AWAKE voltages come on from U7800.
ajdoc
Soldered wire with SE032/3 and 4.
No DFU mode with battery and charger. The same without battery and charger.
PP1V8_SLPS2R 1.8V
PP1V1_SLPS2R 1.1V
PP0V8_SLPS2R 0.79V
PP1V8_AWAKE 1.79V
PP3V3_AWAKE 3.23V
PPVDDCPUSRAM_AWAKE 0.79V
PP1V2_AWAKE 1.19V
PPVDDCPU_AWAKE 0.75V
ajdoc
Please correct me if doing something wrong.
