820-01598 no power
Kyle93
This arrived with a strange no power. Without battery takes 20v and around 150miliamps. On thermal cam U7710 and u8110 were getting warm. Replaced both but no change except they do not get warm now. Also cannot get it into dfu mode
The trackpad also clicks in the case but nothing comes on the internal lcd or external monitor and no caps lock
Just in case, compare all coils.
Don't forget SSD's ones.
Do you get all SLPS2R and AWAKE volatges?
Try external switch method, to force the machine in DFU.
All coils compared looked good.
Tried external switch method, ran dfu revive which finished with no errors however no changes
If no important data, try DFU restore.
If need data, can be saved in DFU mode, by an Apple authorized workshop.
pp3v3g3s 3.3v
PP1V8G3S 3.3V
PP5VG3S 5V
L7030 is 12v during the first few seconds of power but then drops to 7v and stays there until unplugged
L7030 is irrelevant.
Still no voltage L7702 & L8102?
Trigger PMU_ONOFF_L and check for drop pulse at PCH_PWRBTN_L.
