820-01598 thermal sensor issue
the board does just like the older mac board used to do. The fan slowly ramps to full speed and it's laggy. Is there an smc bypass procedure for the newer models?
diode mode to ground on i2c_tpad_3v3_scl is 1.466 and i2c_tpad_3v3_sda is 0.958 . i remember you telling me that the readings on a data bus line should almost match.
Too big difference; check on the other side of Q6861 too.
Inspect R6877/8 and R6812/3.
Did you check in diode mode w/ and w/o trackpad connected?
those reading are without the trackpad cable connected. i2c_tpad_3v3_sda reads the same on a known working board. i2c_sense_scl seems to be culprit. I2c_sense_scl is 1.992 and i2c_sense_sda is 0.471 in diode mode to ground
