820-01700-05 - powering on no image also on external screen
shlom
Hello
having a problem with 820-01700-05 from 2019 16" macbook pro
unknown history
the machine is powering on (chimes) probably to login screen (double clicking the power button activates the voice over option)..
the backlight seems to be on
but no image on display and also not on external good known hdmi connector and screen.
checked the lcd connector and board in general - looks pretty clean.
can you please give an idea where to start from?
Start with PRAM reset and DFU mode.
Choose first revive option.
Go for restore option, if no important data on SSD.
You can try to recover data (if needed), if is recognized in Target Disk mode.
shlom
hi
pram reset chimes but does not solve the problem
tried revive option - didn't do the trick
same for the restore option.
now the mac no longer chimes but comes on with a bright black screen, than dims and nothing more.
also pram doesnt respond now..
shlom
correct, DFU restore finishing with no error
but again, black screen (backlight is on, but no apple logo or os installation)
also, no chime or pram reset after the restore.
i tried to restore a few times, from machine with catalina and also big sur..
both same result...
Does it have USB activity, or external video?
Tried PRAM reset after restore?
Can you get access to its SSD in Target Disk mode?
shlom
when i connect usb mouse i get the light working on it.
nothing on external video
pram reset does not work after the restore
can't get the mac into Target disk mode...
interesting because before the restore it had pram reset and chime.
now those gone..
Mouse light is not confirmation for USB activity.
Read "How To collection" thread and se if there is USB activity, or really not.
Missing internal/external video at same time, can be caused by bad GPU.
But T2 restore shouldn't lose the USB and chime.
shlom
sorry about that, but can't find the "how to" section
can you please send a link?
just to make sure wheter it has or not usb activity...
shlom
hi
got a usb flash drive with a led showing activity
looks like there is activity on this mac when it's on..
shlom
these boards should have cpu vcore , on the table - when only connected to charger without anything else connected?
shlom
i might be getting it wrong, because i think there is no vcore now..
which i'm pretty sure there was before (there was a chime, pram reset)
etc...
any idea why a restore would cause that?
maybe it was locked?
If locked, must give to user the option to unlock it.
So that is not the reason here.
Try repeating DFU restore few times...
shlom
checked again, for sure there is usb activity..
also, if it means anything, caps lock green light comes on and off when pressed..
will try dfu restore again..
anything that can cause the gpu not to kick in
or just the gpu itself?
