820-01700 20V no power
No-Clean
Board had issues with U2890 and UB090 and was stuck in 20V, fixed that and now I get to 20V but no power and no detection in DFU.
SSD power is missing.
PMU seems to be working fine.
SLPS2R and Awake signals ok but PP1V2_AWAKE_SOC_PLLSOC_F is 0.7V not sure on that one, diode read OK.
Try external switch method to force DFU.
Disconnect Touch ID and add a second switch for PMU_ONOFF_L.
Tried but no luck, I even tried my force DFU method on a different board and that other board did enter DFU, but not this one.
Here is my method just in case:
  1. Short the Force DFU test point (PMU_FORCE_DFU) to any 1.8V line
  2. Connect restore cable to the correct port for T2 restore
  3. Connect to power using a charger and a different USB port after step 2
Ok after checking some more I found PP1V2_S3 to be low in diode read 0.050 vs 0.225 when I inject 1.2V on that line the RAM chips are the only ones getting some temperature.
