replaced cd3217 chips because of cycling issue, the cycling has stopped and i have solid 5v with 0.40 amps, but no power, ppbus is stabile at 12.30v and device is not in dfu mode, curious what to check next, seem to be missing pp3v3_s5
What about PPBUS_G3H and 3V3_G3H_RTC?
Did you follow all the steps to enter DFU ,ode?
Check SLPS2R and AWAKE voltages; on the small coils around U7800.
was not able to force dfu,
still have 5v .30amp all ports, ppbus still only 12.30,
PP3V3_G3H_RTC_X is 3.3v, all ports still 5v .30 amp, i have 3 units all with same issue,
thermal cam shows T2 getting warm, not hot temp about 90 degrees
