820-01700 5V 0Amp liquid
raainxx
i have this board liquid spill U7800 is short on signal PP3V3_G3H_SOCPMU.
i remove the component short is remove, but is in the component.
Can I change it to keep on donor board?
thanks
Best regards
raainxx
i have change the PMIC for 820-01700. I have 5V 0,050A now.
short is remove, I have PPBUS_G3H=12V
I have PP1V8_SLPS2R short too, when I inject 1V I have T2 chip become hot, can I replace it?
I think 'no' 🙃
thanks
Yes, you can replace it; if you can get compatible version with your SSD size.
Of course, you will lose touch ID function; if you can't get it from the same machine, with replacement T2.
