820-01700-A MacBook Pro 16” A2141 with shorted SSD
sekidata
This 820-01700 board arrived stuck at 5V USB-C. I found a short on the SSD0 NAND chips: it shows 3Ω to ground on L9530 (P1V8_SSD0) and 2Ω on L9580/1 (P2V5_SSD0). When I temporarily remove L9530 and L9580/1, I get 20V on USB-C (0.03A) and PPBUS is 12.6V. But no chime or startup.
Before I transplant the 4 NANDs from a donor board, I’d like to make sure that the rest of the board is functional. With the SSD power rails deactivated, I would expect this machine to chime, then flash the question mark folder. Am I wrong?
Yes, cycling PPBUS 12.6V for 15-20s, then 12.3 for 2s.
Checked NAND seating and solders and all are ok. Of course, there's no guarantee that the NANDs were fully functional on the donor board...
Not only shorted NAND is dead.
Sometime a NAND chip gets bad without bad reading on its power rail.
This kind of restart points to SSD...
