820-01700-A - stuck at 20V 0.07A - tries to boot
quasimodo
Hey guys,
got a 16" here. Corrosion around U7410.
amp meter goes: 0.03 - 0.18 - 0.27/0.31 and jumping and staying to 0.07
put a new U7410 - and replaced all compontens around it.
PPBUS_HS_CPU is 12.6V
resistance to ground on l7410 pin 2 and l7420 pin2 is 7OHM.
what to do? any chance? cpu gone?
quasimodo
yes to the battery, when connected its taking about 4A
96W charger - yes.
DFU-Mode no. no sign of life in apple configurator
That's really strange; did you follow all the steps from DFU tutorial?
Check all SSD, G3S, AWAKE and SLPS2R voltages.
L7410/20 may have low resistance to ground as normal.
Compare with similar board, if possible.
Do you get voltage on other big coils?
