No-Clean
Clean board when the lid is closed or mac is manually entered into sleep mode or if it enters sleep the Mac won't wake up, the CPU feels quite hot and if you plug the charger the Mac makes the charging sound but there is no image or USB activity.
Also tested this board on another known good case and same problem.
Already restored T2 and installed clean OS.
Replaced U4802
Before and after replacing U4802 this are the measurements:
U4802 and J4802 diode mode readings are correct voltages also seem fine.
Replaced U4802
