820-01700 fans on max and reboot
ajdoc
Liquid damage was on Touch Bar connector on logic board and on Touch Bar flex connector. There was a bit of liquid around Audio ICs U6500/20/60.
Cleaned TB connectors. There was a few pins a bit burned. Re-soldered pins and TB start to works fine.
When turned on there was only audio on one side and other speaker sounded like under water.
Cleaner Audio ICs area + reflow of ICs and sound is working on both channels and it is very clear.
After short time TB stop working and after boot there was fans on max for around 1 second and reboot.
Checked TB connectors and re-soldered pins one more time and it was working and after a few hours I did manual restart and now when press power button after a 20-30s fans on max for 1s and reboot - there is no log in screen.
Same issue with connected or disconnected TB.
Any idea?
Machine should boot without TB connected.
So should be corrosion somewhere else in the MLB.
Check SMC bypass mode.
