820-01700 no Touch Bar
ajdoc
Board was liquid damaged around J5100
Resistors around showing correct values.
Diode on J5100 show same values like another board.
No Touch Bar with brand new part.
SPI_DFR_MISO_R = 1.68V
DFR_TOUCH_INT_L = 1.73V
DFR_LID_OPEN_L = 0.02V
DFR_TOUCH_RESET_L = 0.058V
PP1V8_SLPS2RSW_DFR = 1.80V
PP5V_G3S_DFR_FILT = 5.13V
R5103 got correct 4.67k resistance.
SPI in diode mode:
SPI_DFR_MISO_R = 0.458V
SPI_DFR_CLK = 0.458V
SPI_DFR_CS_L = 0.448V
SPI_DFR_MOSI = 0.459V
Any idea?
DFR_TOUCH_RESET_L should be high, I think.
Can you compare with good board?
Check voltage and signals for J5110 too.
ajdoc
Dont have access to working board anymore.
J5110
DFR_DISP_VSYNC = 0.512V
DFR_DISP_INT 0.0V
DFR_DISP_TE 0.0V
DFR_DISP_RESET_L = 1.79V
PP3V3_G3HSW_DFR = 3.34V
In Diode mode:
MIPI_DFR_CLK_CONN_FILT_P = 0.485V
MIPI_DFR_CLK_CONN_FILT_N = 0.485V
MIPI_DFR_DATA_CONN_FILT_P = 0.484V
MIPI_DFR_DATA_CONN_FILT_N = 0.484V
I2C_DFR_SCL_R = 0.445V
I2C_DFR_SDA_R = 0.445V
I compared J5110 in diode mode with another board where SSD failed and got the same readings.
ajdoc
Made a stupid mistake - was checking voltage DFR_TOUCH_RESET_L and flex was not connected.
With flex connected got on R5103/1 1.78V and on R5103/2 1.77V
There must be something else affected by liquid spill.
Possibly bad traces, or even damaged T2 (its touchbar control section).
