hey guys,
This one came with a C9080 shorted. After replace the capacitor the machine turn on and work well..
But if i set on system hibernate and try wake up the machine press a key or click on trackpad the machine restarts give me a kernel panic. This is the only problem..
If i close the lid and open, works fine.. The machine only restart if i set on system to hibernate.. Strange one!
I already test the motherboard in 2 a2141 chassis. Same problem.
I already compare the readings on J4802 to a working board and is the ~same.
the only line that I think has a problem is PPBUS_G3h:
reading diode mode: 0.360V
I measure 2 same board with: 0.420V
But i already spec the motherboard for missing components and its all ok.
Need some directions.
Thanks
Thanks
