820-01814-A 5V - 0.06amp
samstown
Hello,
No sign of life. I see big coil diode mode value is low... Could it be anohter chip than CPU shorted ?
PPVBAT_G3H_CONN - Diode .817
PP5V_G3S - Diode .377
PVCCSA_S0_CPU Diode .012
PP3V3_S5 Diode .330
Big Coil
L7410 .003
L7420 .003
L7211 .001
L7221 .001
L7231 .001
L7330 .001
LA340 .001
LA640 .001
LA650 .001
LA350 .013
LA300 .045
CPU/GPU coils have low values as normal.
You should compare with good board.
The readings also depend by the CPU type.
What about PPBUS_G3H and 3V3_G3H_RTC?
samstown
Thanks. PPBUS_G3H not shorted but 0V.
PPBUS_G3H = .419 & 0V
3V3_G3H_RTC = .400 & 3.376V
F8400 is ok
F7000 F7001 ok
PPDCIN_G3H_CHRG = .529 & 5.14V
samstown
I know what you mean, sorry, indeed it can not be right.
so
PPBUS_G3H at F6700 = 12.27V
PP3V3_G3H_RTC_X at C3100 = 3.37
samstown
Hello, sorry for the delay, I was sick.
I can get into DFU but revive give "AMRestoreErrorDomain error -1 - Failed to handle message...
