820-01814 A1990 WITH 5V 1.18-1.37AMP
5V 1.18-1.37AMP on all ports, ldo are all ok
ppbus is 12.2v
all coils on ssd 0v nothing shorted
AWAKE and SLPS2R is present but pulsing.
tried AC2 having error 4042 after having this error
board suddenly turns into 20v 1.37amp but nothing overheats (thermalcam)
after this i didnt try check for the ssd coil voltages.
anyway board is clean no any watermark/corroded parts.
posible T2????
STOP checking PPBUS_G3H at L7030 on such board.
Did you see any direct connection???
Disconnect battery and test with 87W charger.
Try starting in SMC bypass mode.
Which voltages appear with 87W charger (whitout battery)?
PPBUS_G3H is steady?
Also check AWAKE and SLPS2R voltages.
"with 87W charger (whitout battery)
5V 1.18-1.37AMP"
I doubt about such high current without battery...
