820-01814 no power
Sr. Robot
Hi, got an 820-01814 that doesnt turn on, no DFU mode, no signs of visible damage.
PPBUS_G3H : 0v
PP5V_G3S: 0v
PP3V3_G3H_T: 0v
PP3V3_G3H_T is 5.1v when using the upper left and lower right usb ports (looking at the board from the open bottom plate position)
You can't expect DFU without PPBUS_G3H.
Do you get 5V at R7020?
PLEASE, use schematic refference for components.
Locate it on boardview, then translate to schematic, if needed.
Diode mode to ground at PPBUS_G3H and 3V3_G3H_RTC?
If good, post U7000 basic voltages; P_IN, AUX_DET, SMC_RST_IN, VDDA/P, EN_MVR, A/BMON.
Also check resistance over C7020/23.
Check all coils, including SSD ones.
If none gives the same value as PPBUS_G3H, then is safe to use voltage injection method.
First remove F7000 and see which side the short remains.
