820-01949 - Only 1 USB-C port goes to 20V. Board won't boot
overshoot
Hello,
I've got that 820-01949 that has liquid damage on both side of the board, close to the air intake.
Customer live on an island and the humidity is always a concern here, in conjonction with dust.
Damages on one side are:
- R3208
- R3209
- C3102
- C3512
Damages on the other side are (close to the USB_C rom):
- RB298
- RB293
- RB29C
- RB262
I have replaced those but I am getting only the UB3100_T chip that works and gives me 20V.
Issue is, once it goes to 20V, the amperage jumps to 100mA and then falls back 0.
I was able to charge the battery with this battery however board would not power on.
Board might be in DFU but since the needed port for DFU which is UB3100_X is only giving me 5V 200ma, I assume that won't work to allow me to DFU restore or am I wrong?
The other side where the Rom resistors were completely corroded and traces gone and that I did rebuild still does not give me 20V.
I went ahead and replace the UB3100_X from a 820-01700, same side, same port (lower port) as I've understood this is the way to go but same behavior.
Any hint on what I could do or check next to get UB3100_X to work?
5V is good enough for DFU.
But I expect to have more components affected by corrosion.
Possibly accumulated crap underneath CD3217 chips too.
Thanks!
I've already replaced the chip which has 5V so far with one from a 820-01700 as I mentioned in my previous post.
I've tried to get it to DFU but my other Mac doesn't see it.
I am wondering if I've used the right chip or if I should transfer the pair of CD3217 with the Rom.
I've used U3100 from a 820-01700 to replace UB3100_X from my faulty 820-01949.
Can you please confirm that?
Not sure if this transplant is good.
You should use chips from same model donor board.
Did you try DFU before replacing the chip?
Tried forcing with external switch method?
I went back at it and got one side (both ports) to get 20V.
The side with U3100_X and U3100_T.
However the amperage jumps to 200ma and then drops to 30ma.
Then the port cycles and back at 0ma and jumps to 30ma. It does that in a loop.
I've tried a DFU revive and then restore but it ends up with error 4042.
I've tried a couple of times, same error. At some point during the revive/restore process the trackpad stops clicking.
Since I have the other side with damaged rom chips and data lines that prevent the USB-C circuit to get 20V, I am wondering, would that cause the DFU restore to fail or is the issue lying somewhere else?
Well I can answer my own question.
Yes fixing the other side USB-C circuit did indeed allow the computer to boot up right away without going through DFU.
Case closed.
