820-01949 stuck on 5V after liquid
Restore erases the SSD.
Sometime only that can fix the machine.
Client should understand he MUST take care about data.
People paid lot of many for these Apple bulshits, knowing already the SSD is not interchangeable.
Time Machine is must do option, when install the macOS.
Dozer
yes you are right.
ok so I tried that revive and restore is the same result. both have just in the moment when the message comes installing system.. the drawing ampere jumps from 0.200 to 0.400 then after some time end it up with pictures I posted already
Dozer
SSD0_VR_2V5_EN = 0V
is this not a part of the problem?
what does the restore/revive needs to work? where does the ..installing the system... installing the system and which system.
Many times SSD voltages come on in DFU revive, or restore.
Check diode mode to ground on SSD power rails and all big coils.
