820-01958 20V no CPU Core
down1nit
Water damage near Q7660/Q7680 (p5vg3s and 3v3_g3h). Replaced obviously bad ones, lifted the fets/cleaned pads. Every power is present but CPUVCC and screen/backlight as far as I can tell, even lid signals.
Not stuck in DFU, had to force DFU using keycombos to make sure. Just "macintosh" in sys profiler unless i force dfu. Didn't restore bridgeos, customer needs data preferably, assuming possible.
PCH is getting power and warming up ok, what's next to check on this? Thanks!
You can try DFU revive; it will not erase de SSD.
Restore is the option which does that.
No voltage at all at L7210?
L7400 has correct voltage?
down1nit
Tried revive 2x on a brand new 16" w/ monterey. Seems to complete, then i get a reboot and a lock symbol on the bad device's DFU icon.
CPU still no volt
down1nit
I'm repairing a MacBook Air. The 16 hosts apple configurator 2, I was trying to revive the Air board using the 16 lol. The battery seems good. Battery LED illuminates and my ammeter reports 2amps being sucked into battery.
down1nit
Yeah I think some got under there. The CPU sorta just asks itself to be enabled when all the conditions are met right?
CPU core voltage generation is complicated.
Is not just enable signal required, like for other secondary power supplies.
