820-01958-A: completely dead: no voltage no amp
phantom
hi, please help! i have
820-01958​
dead: no liquid spill or damage.
amp meter stay completely off in both ports...
i have 4ohm resistence on
PP20V_USBC_X_VBUS and PP20V_USBC_T_VBUS
If i go on those line with power supply with 1v 1amp, it goes directly to 0,27v 1amp in both lines but i can't see anything hot
"1v 1amp"
If you have pure short, the board tries to sink way more current.
PSU will NOT inject anything, if you set 1A limit.
I ALWAYS said on the forum: set amp limit to MAX on PSU first.
D3300/20 are the first suspects; or D3302/22, if soldered.
If the CD3217 chips are bad, you should find bad diode mode readings on several lines.
phantom
I mean that I have set power supply with 1v and amp limit to 1amp
And as soon as i touch the line, motherboard sink 1amp
I’ve removed both cd3217 but short persist in both lines
Try to get them from scrap boards.
Machine will work without them; of course, no overvoltage protection anymore.
This kind of failure is caused by bad/fake charger.
"motherboard sink 1amp"
And dropped to 0.25V, becuase entered in protection mode...
