820-01958 no image
Dildobagins
Hi
I have a problem with logic board A2179.
I replaced the L8750 and the u8500. In addition, I replaced the burnt fuse of the F8400. I received a screen backlight but no picture. I additionally replaced u8595 but without positive result.
Can I do more ?
Any history available?
What was the reason to replace all mentioned components?
Did you test with known good screen?
Do you get external video?
No hisotri. MacBook suddenly stopped working.
I replaced all components because everything was burned. I had to rebuild the damaged pads.
No picture on the external screen.
Unfortunately I do not have another screen.
Not sure about your readings; check schematic and boardview.
Pin 2 is ground!
You should get very similar readings at pins 1 & 3.
U8595 is not image related.
Don't change things without reason.
Check DP_INT_HPD and 3V3_S0SW_LCD voltage (with LCD connected).
"DP_INT_HPD - 0v"
Are you sure about it?
Is strange to get even backlight in such case; as PCH didn't recognize LCD.
I recommend to test with known good screen assembly.
