820-01958 no power
Kyle93
Arrived with water damage. After replacing affected components the board powers on to 20v at 0.12-0.14a
Strange, can hear a buzzing noise coming out of the board. Sounds like it either coming from the T2 chip or U7800
Tried DFU mode revive option which completed successfully but no changes.
What should be checked next??
So board turns on, but doesn't boot?
You may need to use restore option.
Ask the client if has data unsaved first.
Kyle93
Yes but no change after restore option.
When the board is on the bench if one of the screw holes to the left of CPU is just tapped with finger the buzzing noise goes away and the board jumps up to 0.24a for a few seconds. Once unplugged and plugged back in buzzing noise returns within a few seconds
Audio board was also affected by liquid?
T2 data lines close to PPBUS_G3H and liquid spill damage it easy.
I suppose T2 chip got bad and doesn't work properly.
Already discussed few times on the forum, about such possibility:
Pretty hopeless...
