820-01987 20v 0amp
Kappy
I've got an 820-01987 which the customer says just switched off. I've had a look under the microscope and there is no sign of any liquid damage to any of the components. It's been ultrasonic cleaned and after probing around I've noticed that all the AWAKE and SLPS2R rails are pulsing. These all come from the U7800. I'm getting a stable 3.3v on PP3V3_G3H_PMU_VDDMAIN and PPBUS is also stable 12.27v.
Am I correct in saying that the U7800 is faulty or is there anything else that it could be or I could check.
Thank you in advance
Kappy
PMU_COLD_RESET_L is also pulsing
Not tried it with a battery as I would have thought it would work fine with just the mains plugged in.
Kappy
With is showing 0amp I was a bit sceptical but tried it anyway. I used a brand new battery which has 60% charge on it and it's still showing 20v 0a
Kappy
Yes same as before.. I really can't think it's anything else than something around the U7800 or the chip itself. Do you know if this chip is firmware locked to the board?
I'm just waiting for the go ahead from customer to remove the shielding that covers the U7800. The other option will be to sending back to Apple for a replacement under the Consumer Law.
Check if machine is covered by some Apple warranty first.
"The other option will be to sending back to Apple for a replacement under the Consumer Law."
Sounds like best option...
