820-01987-A 5V
tipoti
3V3_G3H_RTC : 3.3 volts coming and going. There is voltage for 5 seconds, then there is none. Then it comes again
I guess I need to remove the cage on the u7800. What voltages are required
T2 requires several AWAKE and SLPS2R voltages to start.
PPBUS_G3H also fluctuates?
Both USB-C ports have the same behavior?
Check diode mode to ground on all coils.
tipoti
PP1V1_SLPS2R : 1.1 Volt
PPBUS_G3H: 12.29 Volt volts coming and going. There is voltage for 15 seconds, then there is none. Then it comes again
Both USB-C ports have the same behavior? yes
u3200 region a little warm
tipoti
The u8472 is punctured I think. u8472 pin 1 was showing short with gnd. I removed the u8472 and r8455. R8455 pin1 short circuit Is u3900 faulty?
