820-01987-A not detecting battery
Soji
The macbook came with no data Acess on both type-c port. But it’s charging.
I changed both cd3217, one of the port is not working if I turn the type c upside down and the macbook is not detecting battery anymore , if I remover the charger cable the screen will go off, no battery logo at the top right of the screen.pls help.
Soji
one port charge correctly both direction, and the other one works only in one direction yes.
the cc1/cc2 lines has same diode reading 587.
And machine doesn’t turn on with battery alone. If I power it with charger it comes one but when I remove the charger it goes off. And no Battry logo on the screen too.
D3328 usb_xa_usb_bot_n is ripped off
D3354 usb_xa_usb_bot_p is ripped off
D3354 is connected to USBC_XB_USB_BOT_P.
You may have another damaged component, or broken trace; check under microscope.
Also remove USB-C ports and inspect their terminals.
Post PPBUS_G3H and PP3V3_G3H_RTC voltage with battery alone (no charger).
