820-01987 A ...... PPBUS_G3H Short
Help me remove the shorting from the board
No signs of Physical Damage or Liquid Damage
No history and Board looks clean under the microscope
Input Voltage : 5 V
F 7000 Pin 2 : 0.50 V & 54 ohm RTG
If the low resistance to ground doesn't come from any coil, then is safe to inject voltage.
Is not pure short, you will need higher voltage than usual; however, do not exceed 15V.
Start with low as 1V and slowly increase the voltage. Set first lab PSU amp limit to max.
Thermal camera can help a lot in this case, as probably nothing gets really hot.
Short Removed
Now
It is talking 0.60 mA
F 7000 = 12.35
L 7030 = 5V
WHat should be the best step?
Stop to test L7030 coil in the buck-boost converters.
No idea why the people still check voltage there; so dificult to see it is not directly connected to PPBUS_G3H?
Check if is detected in DFU mode.
