Hi, this board had liquid damage around U2800 and found a short on PPBUS_G3H that was caused by C9081. Now the board is taking 20v @.08mAmps, can access DFU mode, but get error message when I try to restore it...
Not low value, but there should be stable voltage.
Compare diode mode reading with similar good board.
U9080 may be affected by corrosion; you may need to resolder, or change it.
Check all its surrounding components; pay atention to R9080/81/83.
PPBUS_G3H is at 12,33v but goes a little high when F7000 is in place...
PP3V3_S5 = 0
PP1V8_s5 = 0
PPVPCORE_S5 = 0
PP1V_PRIM = 0
RSMRST_L = 0
SSD0_VR_P2V5_PGOOD = 0
