820-01987 no power
Kyle93
Arrived with liquid damage on trackpad connector and a few capacitors. Pads 50-44 and 49-43 are completely gone on trackpad connector. PPBUS_G3H is shorted.
Only 3-4ohms resistance to ground on two of the large CPU coils.
What should be tried next? Using 820-01598 boardview as a reference, cant find 820-01987 boardview
Probably the short is caused by trackpad connector, remove it.
Also compare resistance to ground with all big coils, just in case.
Kyle93
short is still there after trackpad connector removed,
resistance to ground on big coils is different then PPBUS_G3H resistance to ground. PPBUS_G3H 1.8ohms. CPU big coils 3.9ohms. All other big coils are much higher
Then is safe to inject voltage.
Start with low voltage as 1V, and increase maintaining the current under amp limit.
Kyle93
Injected voltage and only area that gets warm is the trackpad area. Did some scrapping but short still remains.
Does This look like a hopeless repair?
