820-01987 Stuck on 5V
brunomotter
Hello. Got this board here. Very clean, no signs of corrosion. It negotiates only 5V with charger. Already checked for shorts, no shorts found. Replaced both CD3217, same issue. Tried replacing U7000 too as I'm not getting CHGR_EN_MVR, but same result... I'm stuck... I'm not good at this new architectures, need to study more to understand how it works. Any ideas on what to do next?
"PPBUS_G3H is stuck on 1V"
Check diode mode to ground there.
Post U7000 basic voltages; P_IN, AUX_DET, VDDA/P, SMC_RST_IN, A/BMON.
Check resistance over C7020/23 (ohm scale).
brunomotter
Diode Mode to GND on PPBUS - 0.431
P_IN - 5V
AUX_DET - 1,289V
VDDA/P - both@5V
SMC_RST_IN - couldn't find a point that's not under the nasty shield to measure this one
AMON - 0V
BMON - 0V
C7020 resistance - 3ohm
C7023 resistance - 2.6ohm
All look good there; you should get there PPBUS_G3H.
Remove F7000 and check C7050 voltage.
CHGR_RST_IN is available at U/R6940.
