820-02016 not working
bartech
there is short on ppvbat_aon_chgr_reg, i change u5200 but the same
i take out r5261/2 and short is alsow on chgr_cs_p/n
Then why replaced U5200???
What is the exact ohm resistance to ground?
Compare with the readings on all secondary coils.
come back again, it starting and work till you try to watch youtube... when you push play on youtube - pink screen and restart, now its not starting.when i connect power there is shot on F5200 and u5200 get hot but changing u5200 dont change anything
"when i connect power there is shot on F5200"
Are you checking in diode mode with power applied???
Allow 10-15s once power is removed (including battery), before checking in diode mode, or ohm scale.
ppbus_aon - 4.5v u5200 get hot, changed - the same
u5700 only pbus_aon - 4,5v i change it but the same
Then your problem is on U5200 area.
Check R/C/Q5230/40 and their traces.
Be sure all resistors around U5200 are good.
i change q5230and 40 and start working but still got problem that when i try to use youtube or even conecting charger it reset because of sound, i found problem - ur600 . i change that and now sound work and dont restart. thanks for help
