820-02020-A not charge
Paky46
Hi, I have this board that does not charge, when connecting the charger it absorbs 5V
the customer says that it has stopped charging and now the battery is completely dead. Fortunately I do not find any shorts. Where can I start?
You only mentioned battery not charging here.
So now you say machine not working with charger alone?
Why then you fix on not charging battery?
Please, describe correctly the problems on your posts.
Post PPBUS_AON and 3V8_AON voltages with charger alone.
Paky46
the customer told me that it doesn't charge but if I connect the charger I have no sign of charging at all, it only absorbs 5v
PPBUS_AON=0.7
PP3V8_AON=0.8
the voltage of PP3V8_AON when I measure it tends to drop
