820-02020 don't switch off lcd when closed
Inspect UR200 area for corrosion.
Check AMR_LEFT/RIGHT_OR_ND_1V8 and IPD_LID_OPEN_1V8 signals behavior.
bartech
i disconect power button and macbook start to switch off lcd when closing, whit other button connected lcd dont switch off
No need to connect the LCD.
You can test left sensor JR200 with a magnet.
Is not so easy with right sensor, placed on right speaker area.
bartech
i chek whit magnet amr left whit magnet go to 0v, whithout there is 1,8v
the same whit arm right 1,8v - 0 v whit magnet
IPD_LID_OPEN_1V8 - nothing happening stay at 1,8v all time
bartech
traces look ok i even take out ur300 & ur200 and there is connection. i put back ur300/200 and the same no switch off lcd when closed
bartech
i check whit magnet when its workin on top case and it switch off but magnet need to be strong. when i close not for 100% and use magnet on jr200 side it switch off
bartech
problem is whit magnet at speaker next to jr200, i take out the magnet from speaker and now its working normal.
