820-02020 M1 Displays on external but No internal image
huzeafa
Good day guys, I have an M1 board, that does not display on the internal screen, No image or backlight, but I get display on an external screen. The board is clean, I have tested with a different screen but no changes, I tested the original screen with another board, and it displays.
PP3V3_SW_LCD_CONN= 3.3V
PP5V_SW_LCD_CONN= 5V
EDP_PANEL_1V8_EN= 1.8V
LPDP_INT_HPD= 0V
I2C_MLB2JERRY_3V3_SCL= 3.3V
I2C_MLB2JERRY_3V3_SDA= 3.3V
I2C_ALS_1V8_SCL= 1.8V
I2C_ALS_1V8_SDA= 1.8V
PLEASE HELP ME WITH WHAT NEXT TO DO/CHECK.
"LPDP_INT_HPD= 0V"
M1 expects high voltage, in order to enable internal video.
Did you change the small video cable too?
This signal comes from LCD assembly.
M1 may have an internal damage and pulls down the signal.
Compare diode mode readings on JP600 lines with good board; w/ and w/o LCD connected.
