820-02020 no lcd and backlight, lite water damage
Bad news, there are many chips connected.
Injecting voltage will not heat something to find with fingers; an IR cam may help you.
I recommend to remove UC810 first and check if low resistance disappears.
yair37
I was take UL000 out the S2 line now 0.300 and PP3V3_S2 3.3v
there is Chime sound but DP800 0V with screen connected of course.
PPVOUT_LCDBKLT_SW 0V -800 on DP800
PPVOUT_LCDBKLT 0V 1080 on DP800
3V3_SW_LCD should appear, at least in the first few seonds (when chime).
LPDP_INT_HPD must go high at same time.
