820-02020 stuck @5v
phantom
you mean comparing with opernboardata?
now i have 0,200 / 0,600k resistence to ground
openboard data says 0,400 /40m :(
PP3V3_S2_WLBT_ISNS is 0,025 in diode mode,47 ohm resistence to ground
phantom
why you say that? on PP3v3_S2.i've no short anymore...if i go with power supply on that line, nothing happen....so i think this line is fixed?!
soldering an 1.5UH-20%-12.5A-0.01OHM (just for test) in the place of lc710, i have 0,430 diode mode and higher resistence (i'm not able to read the value because it change continously...like from M to K)
but 3,3 is not stable
https://www.dropbox.com/scl/fi/4p5z...2-00.mov?rlkey=ulkqu7tudzu4cwqfskhjonmjm&dl=0
"now i have 0,200 / 0,600k resistence to ground
openboard data says 0,400 /40m"
You've reported half reading of expected value.
Something else must be affected.
Now you say to have 0.430; not sure which value is real...
phantom
THIS IS REAL
Probably previous reading was bad.
The value can't increase if you connect something more there.
Ohm scale is usefull for very low values, under 0.010 in diode mode; don't bother with it in this case.
P3V3S2_EN fluctuates?
phantom
PPBUS_AON 12,2v stable and 3V8_AON 3,7 stable
on u8100
PP1V2_S2 0v floating 1,2
PP3V3_S2_UPC floating 3v/2,5/1,6/0
PP1V8_AON_MPMU 1,7
MPMU_VREF_ADC is 0,020v
on u7700
PP0V72_S2_VDD_LOW 0v
PP1V2_AWAKE_PLL 0v
PP1V8_AON_SPMU 1,7 stable
PP0V855_S2SW_CIO 0v
PP0V805_S1_VDD_FIXED 0v
PP1V2_S2_CIO 0v
May have bad solders on U8100, or even bad chip.
Also may have problems with a secondary voltage.
Check all power rails in diode mode; start with LC320.
phantom
i've check on all 6 big coil...all ok except
P3V8AON sw1/sw2/sw3 shouls be 0.350, i have 0.150
reflowed u8100...no luck
so you think about u8100.....but why you give me a link about wifi chip ?
