820-02098 5V
No-Clean
Board came with a short on PP5V_S2SW_USBC23 both UG400 and UG800 were shorted, after replacing both of those from same donating board I now get 5V on all ports, but in the port where I replaced UG400 if I connect the power cable there PPBUS is 2V the other ports give me 12V PPBUS, I tried 2 different CD3217 from other boards and even UG260 from same board but same thing.
No-Clean
Thanks, UF980 was shorted, replaced it and short is gone, all LDO lines are on par with with board and surrounding components also measure same as good board, but I still get the same behavior bad port 0.021A other ports 0.250A no restarts, I installed another UF980 and also UG400 but same thing still.
No-Clean
Diode readings around UG400 are now on par with good board
PP1V5_UPC2_LDO_CORE 1.5V
PP3V3_UPC2_LDO 3.3V
USBC2_3V3LDO_EN 0V
