820-02098 - Starting up but amperage limited when charging
overshoot
Hello,
Working on an 820-02098 (M1 14" Pro) that had a previous repair attempt and some missing USB-C chips.
Long story short, I've replaced all the USB-C and ROM chips from 2 donor boards since each donor board did not have them all (820-02098 and 820-02443).
I believe these boards had good USB-C chips but uncertain.
Previously I would not get PPBUS_AON when connected from some USB-C ports but now I do from all of them, including LDOs.
However I am not getting 20V, just 5V with about 120mA, fluctuating.
I have also replaced the CC protection chips (on UF400 and UF500) since these were re-balled poorly and killed one of my donor CD3217B12.
I am now trying to revive/restore the board to see where the log would fail but the Mac won't go to DFU or won't be seen from the host Mac.
I am however getting 20V with 100mA when the board is in its housing, battery connected.
That was yesterday.
I left the machine overnight plugged to the charger and this morning the laptop was on, with the battery partially charging.
Yesterday as soon as I was pressing the power button or the trackpad, the charger would reset itself, so I am thinking there is some kind of limitation in the amount of power (amperage) it can take.
Can a restore fix potentially an issue with the ROM software mismatch?
Any idea what could be going on please?
Using macvdmtool, I can put the Mac in DFU (it seems) as the Mac shuts off.
I can also reboot it using another macvdmtool command, however the host Mac won't see the device so I can't restore it.
Can a faulty ROM cause this behavior?
Or if any ROM would be defective I shall not be able to get 20V when the system runs on battery.
I was able to get the board to be detected in DFU mode.
I went through a restore and the restore went through, no error.
However I am back where I was with 5V 100mA on charger only or 20V 100mA on battery.
Having the DFU restore succeeded, does that mean the USB-C part is fine and I should looking elsewhere?
I would appreciate if you would have any idea or hint to give me.
I am stuck on this board and so close.
I have one more day before I have to give back this device to the client.
