820-02098 When power cable or MagSafe is connected MacBooks reboots constantly
No-Clean
Clean board, tested same behavior on a different case with known good battery and same problem, tried restoring in DFU but as soon as the cable is plugged in MacBook restarts constantly, if power cable is unplugged Mac starts up fine, same thing happens with MagSafe, happens in all ports. Ports do work with data, all of them.
Checked around U5200 and all is fine, but replaced U5200 regardless and same thing, I dont even know where to start.
No-Clean
I replaced both those caps and Mac started charging, the other steps you mentioned I did check before and all of them measured fine.
