820-02098
tipoti
Hello, I hope you are having a good day.
the device came to the service due to liquid contact. When I received the device, it was running on battery, the keyboard was not working. There were liquid contacts on the motherboard. I cleared all of these. I changed trackpad flex.
I changed c5268,c5264,c5263,c5264. The device is now turning on. But it is charging, it says 1% and there is an x sign on the battery. When I remove the charger, the device remains on. When I plug it back in, I get the charging sound. Is it a battery problem or is it caused by the motherboard? I don't have a spare battery at the moment.
PPVBAT_AON : 12.20 Volt
The battery did not pass the presence test, there is no other problem. I think I should try it with a different battery. ?
