820-02098
Kyle93
This arrived with no liquid damage or power. When plugged in amp meter goes to 20v and up to .200amps stays there a few seconds and then power cycles. It appears all voltages appear before the power cycle. Only the heatsink gets warm under the thermal cam.
What should be checked next?
Yes but no luck. Is there a certain power rail that can be measured which can show if the M1 is at fault or not?
